porsche356
Everything posted by porsche356
  1. Hi, My cayenne tt '03 has developed a new habit. Usin the remote will on occasion (not allways) open just 2 or 3 doors. If I touch the doorhandle then it opens (entry and drive system is on my car). Using the ''open all'' button in my driver door opens all the doors as well. Therefore it will not be one of the door engines. Because it does not happen everytime I am wonderin whether replrogramming of somethin will do the trick? Any advise? Can I reprogram myself as well? Thanks, frank
  2. Thanks Loren, I willcheck it this weekend. Frank
  3. use the search on the side. There is a great DIY on the site. If you can't find it let me know, I'll send you the link (replacement turbo cluster). Good luck, frank
  4. Hi, My little girl left one of her toys on my 997 cab. I was not aware, today I opened the roof. The toy got stuck and prefented the roof cover to close correctly (the cover near the engine hood that covers the hood when the top is down). I now need the adjust the closing of my top cover (there is one seam on the side which is now too wide). I noticed two bolts underneath the top on each side which give a bit of adjustablilty. Just wondering whether there are more possiblilties to adjust the topcover? Thanks, frank
  5. Hi, Just noticed that my front hood doesn't close very well in line with the bumper (when closed). Just wondering whether there is a possiblity to adjust the vertical hight at the bumper side (not the window side)? Thanks, frank
  6. FIXED!! Quite easy, just took out the instrument cluster (15 minute job, very easy). Then removed the back from the cluster (white part). There is a small speaker attached to the white rear. Mine was broken. Just bought a replacement speaker at some elektro shop (3$). Put it in and it works great. All the sounds are back and even more clear than ever before. Took me a total of less then 50 minutes, and..... much cheaper than replacing the cluster. Frank.
  7. The story continues: My indicator workt fine, but the sound is 'gone'. I do hear a very soft klik-klik but this could be the relais as well. If I open my door with the light on, the warning sound works, but it sounds like a badly tuned radio station (cracky noice). Same goes for my seatbelt warning sound and the passenger airbag off sound. It works but thesound is like a broken speaker. I want to check the wiring and check the speaker for dust, but where is it located? If it is in the instument cluster, how can I remove this? Thanks for the help, Frank
  8. Does turning the PSM off make such a difference? I went by the dealer today for something else. I asked them whether this was normal. They said that it was programmed to give the power gradually in order to prefent to much power all at once going to the drive train. I will try it with PSM off! Thanks, frank
  9. Hi, I allways experience a strange thing with my wifes cayenne TT (2003). When I drive the car I allways start slowly, as soon as the engine is warm and the road is clear I push the throttle completely down. What happens then is that the car shifts down 2 gears (depending on the speed) and then starts accelerating. This acceleration goes in a strange way. It feels like it starts to accelerate and then adds on more power every second. Feels like the power is added in 4 or 5 steps. As soon as I have done this a couple of times it feels like the engine and gearbox are awake. This means that the next time I push the throttle down it gives me full power instantly. After driving normal/slowly for a while, the procedure starts all over again. Is this a programming issue? If so, can it be changed. If not, what could the cause be then (coils?) ? There are no lights burning, engine sound good. Any comments/ideas? Thanks, frank
  10. thanks Loren, you helped me out once again. Regarding the aluminium trim: is it just a matter of pulling it off or do I need to move it sideways before pulling? Thanks, frank
  11. Hi, I need to remove my rear door panel (interior) in order to check my lock. Before I ruin things I thould it is best to ask the people that know how to remove the panel? Pics would be great. thanks, frank
  12. I don't know the precise dimensions. I do know that I have 7" in my cayenne TT! FRank
  13. I would love to have one. Which one should I buy? Is it the same for a cayenne as for a 997? Thanks, frank
  14. Hi, All of a sudden my right rear door stopt locking. Is there something I can reset or check or is it most likely that the locking mechanism (motor) is broken? Does somebody have the schematics on how to remove the side trim of the door so I can check the motor and wiring? Thanks, frank
  15. Hi, My 2003 TT does not make any noice when I use the turn signal. Could anybody tell me where the sound thing is located and whether it is easy to replace? Thanks, frank
  16. Hi, I have to remove the 12pin connector. But I would like to leave the center console in place. I have removed the interior to the right of the PCM and I can see the connector. Is it possible to remove this plug with the console in place? Perhaps ''through'' the tiptronic lever? Regards, frank
  17. Hi Loren, Thanks for the pics. This should work (not quite sure about the removal of the first part: removal of the button). Do you perhaps have the same of the removal of the center part (where the handbrake is, not the PCM part)? Thank, frank
  18. Hi, I have encountered a new problem. All of a sudden , my interior light stays on as long as the car is open (also when driving). I went by the dealer today but they could not figure it out. Did someone encounter simular problems? Thanks, frank
  19. Question 1: No, the light should be installed as well
  20. To answer my own question. Yes there is already a plug under the dash which should be used. Frank
  21. Hi, I need to remove my tiptronic knob from the lever because I have to take out the center console. Only not sure on how to remove the knob? Could somebody please explain me the procedure? Thanks, frank
  22. Hi, I am about to do the TSB 6629 (passenger airbag installation) a I was wondering two things: 1. Is it possible to install the switch without installing the warning light (PAO) in the center console (I don't like it and the display also shows a warning)? Or does this lead to an error message? 2. I have studied the TSB for a long time but I can't figure out where the airbag plug comes out of? Is it allready fitted in the car and ready for a plug in? If not, what happend with the plug that was initially in (TSB mentions nothing about this airbag plug B besides plug in the 'new plug'). If I am correct with my assumptions than I could remove the glove box, plug it in and PIWIS it and done? (offcourse starting with taking of the - pole of the battery) :-) I know this is quite detailed but help is appreciated. Thanks, frank
  23. Hi, check the answer of Loren. These are the correct bults, 24 and 25 do not work. Frank
  24. Hi I would like to do the TSB airbag deactivation on the passenger side. I have ordered the module at carnewall. I know the dealer has to do the programming part, but the installation looks like fun to me. In order to not ruin everything I would need some more information on how to remove part of my dashboard. Could somebody please help me on: Removing and installing the glove department (681519) Removing and installing the center console (681719) Removing and installing the cup holder (683019) Removing and installing the right dashboard cover (701619) Removing and installing the cover under the instrument panel on the passenger side (701919) Removing and installing the cold air cover (702219) Thanks a lot. Frank
