Flyer007
Everything posted by Flyer007
  1. Ditto on the thanks to all the wonderful contributors here!!!!! This site was the number one reason I felt comfortable with my first pcar purchase this year.
  2. I have not heard anything on this one. Did you get the 99' C4? That is a sweet ride with a TON of mods (the right ones also)!!! It came on sale two weeks too late for me. (I had just bought and shipped one from TX to Boston) Not sure if you have previous pcar experience, but as a new pcar owner myself......you'll love her.
  3. Could be ignition switch broken. A lot of times mechanics not familiar with car can torque the key to hard and break it. Try wiggling the key (more counter clockwise) and see if the offending systems recover. The plastic piece can be found on ebay and Autozone online. Do a search here for part number. it runs from $14-30 depending on source. Can be a DIY replace (instructions also on this site) Good luck
  4. My 99' C2 will turn off without locking. I have not timed it though. I have left it unlocked twice in garage overnight without any issues. It also has an aftermarket Alpine radio in it.
  5. With my 99 C2 I found that the headlight plugs were loose. This affected all the lights in strange ways. You can check this by removing the headlights then reaching into the fender. See if the plug is loose in it's holder. There should be a sliding clip that keeps it in place. On mine this clip was not engaged. The only other easy item is maybe a faulty ign. switch. But since it is just that one light then probably not.
  6. I agree that the shop should had done it but the car came this way. I was going to hold off until I figure out what I want to do suspension wise to get another alignment. I know that other cars have the adjustability at the steering box. I just wasn't sure about this one. Thanks
  7. Ok. So my new to me MY99 C2 seems to be aligned great! But I notice that the steering wheel is just slightly to the right when the car is going straight. Is there a way to adjust this? I searched but came up dry. Thanks, Ben
  8. I have my eye on the escort 9500i with the GPS built in. It also can be set to adjust sensitivity based on speed. So tooling around the parking makes it less sensitive.
  9. Rotorhead.....did you get that w205? Was there only 1? I have been looking at that unit also and that is a steal!
  10. Thanks I will check them out. Ben
  11. Wow....having just got my first p-car and am probably going to need breaks soon I looked around and could not find that pricing. Care to share? Thanks, Ben
  12. Was the RMS leaking or did they just replace it for the hell of it?
  13. Ebay is your friend. http://cgi.ebay.com/ebaymotors/Porsche-996...sspagenameZWDVW
  14. 1. This thread has trim part number http://www.renntech.org/forums/index.php?s...2;ac+trim\ 2. I found another post somewhere that mentioned a cross member was between (horizontil to divide the two dins vertically) the two Din slots and was easily cutout. This is fairly common in most vehicles. Have you gone and played with the different Nav units? That is the one thing holding me back. So far I find most of them to have very cheesy feel. To the point that I am now thinking of doing the mini PC mod. Or keep the Alpine 9856 and add a Parrot BT for phone and a Alpine 422i cable for my iPod. One unit I have not tried is the combo Alpine w205 with blackbird. That seems interesting since it allows you to take the GPS with you to other cars. It has full iPod control but no HD to rip cd's too.
  15. I am getting my new to me MY99 C2 (non PCM but aftermarket Alpine 9856) on Monday and have been thinking the same idea. After having done a ton of research I have found the following. 1. The AC controls will easily move down with a $7 trim piece from Suncoast. 2. Some cutting will be needed in the Double Din area if it was a car that had no nav. I am not sure about the Bose infacing or if you loose any functions remove the PCM. Do you have a iPod? If so why look at the units that rip to HD? Just get an iPod controllable unit. Good luck and let us know what unit you picked.
  16. They look like these Brombacher ones that are coming on my new to me MY99. These are also 19"s Has anyone reported issues from spirited road driving with 19"s on MY99-01? Hoping not since these look incredible.
  17. Hi guys, Well I pulled the trigger on a MY99 Coupe. I am searching for a shipper to get it from TX (Dallas area) to MA. Any advise on ones to use or to stay away from? Thanks, Ben
  18. Thanks, I had thought about that. One of the cars on list so far has red interior. Wife not liking the pink fade.......
  19. In my search for "the one" some interior carpets are showing some fade. This of course gets the wife turned off. For the life of me I cannot find replacement carpet for 1999-2002 996 cars. I looked at Sunset site, googled it etc. Are 996 carpets listed differently? I have also looked by searching 1999 911. Also are the lower carpeted parts of the door replaceable easily? since that is where she notices it most. Thanks, Ben
  20. Thanks guys for all the input. 1. PPI......YES! Saw that advice numerously here. 2. Car is for both of us. It will be mostly my good day commuter (sharing good days with my Ducati that is) What major maintance differances between coupe and cab? Other then obvious top motor and parts. are 4+ cycles of the top a day overkill? 3. JohnJ I am sorry to hear about your problems. What was the failure? From this board it seems that the main issue is RMS or inter. shaft seals failing and letting oil run low. What are the other major issues? Those seals were visably inspected 5 miles ago (FW replacement) and found to be dry. 4. Some known options so far are Aero2 wing, 2pc 18" wheels, Litronic Headlights, 3-spoke steering, full leather, heated seats, LSD (is this an option and how common) 5. Dealer seems to be a well established ind. Dealing in mostly highend vehicles. 6. I am in MA will correct profile. I have seen some C4's slightly above my range. What are the frontend maintance like on those? Is it a worthwhile move to that? Thanks for all the input
  21. Great info here guys. I am shopping for a 99-01 996. My budget is upto 30k. I have found 99 coupes with milage in the 40k-70k to be in that budget. Mostly are dealer trades with limited history notes. One in particular is a 99 silver ext with red int. C2 coupe. It has 42k miles on clock. The dealer didn't felt some vibration so had the clutch and flywheel checked by a Porche ind. shop. Clutch had plenty of meat left but they stuck a new stock FW in it. Now fine. The shop said the RMS was dry also. The only other known issue is they is a slight vertical crease near the edge of the hood about 1.5" long. Looks like someone had left something in the channel when closing. Carfax shows a minor accident in the rear at 32k miles. 2 owners 1st was a lease 2nd college kid that only drove 10k miles for 5 yrs he had it. Dealer is firm at $26k What milage should I be looking at for this budget? Is the maintance different bigtime between C2 and C4? Wife thinks she want CAB. What should I be looking for in these? Thanks for the help! Hoping to be an owner in two weeks!
