coreseller
About coreseller
    Midwest
    1996 911 C2
coreseller's Achievements
  1. Your disposition regarding the death of your Porsche is commendable, it's nice to see people take the high road and see the forest through the trees.
  2. I found my homemade tool, will send it up your way if you want it. PM me your address.
  3. I had not seen this thread in awhile and since writing it I wanted an addendum; I did not use the cam locking tools in this project, since completing it I have learned that it would be prudent to do so to avoid your motor "jumping time". I have an '02 S which means I have the 5 chain motor which was used in cars up to 2003, 3 chain motors were used in later cars and were more prone to jump time if not locked down during the procedure. Per my write up, I simply followed Jake Raby's instruction which worked beauitifully for me on my car.
  4. I used Gorilla Glue. Be careful, that stuff expands as it dries so recheck the depth if you choose to use it. Clamping it should help.
  5. If it were me I would indeed put two of the upper bolts back in and one on the opposite /passenger's side back in. Any weight of the tranny putting side forces on the triple square bolt head is only going to make your job more difficult. Also, I believe Liquid Wrench or PB Blaster may penetrate the threads better than WD40.
  6. If taking this on yourself: 1.) Sachs Clutch kits can be had cheaper on ebay: http://cgi.ebay.com/ebaymotors/00-04-BOXSTER-S-3-2L-3-2-PORSCHE-SACHS-NEW-CLUTCH-KIT-_W0QQcmdZViewItemQQhashZitem1c128d055aQQitemZ120570316122QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories Flywheel should be inspected for movement to ensure it's within spec. You should clean up the face while in there. 2.) My money would be spent on the IMS Retrofit if I were in there, I'm not sure an '07 porsche Replacement motor could accept the retrofit though. 3.) News to me, not sure.
  7. I will second iatros' comment. The Porsche world is better off with this guy's help, be sure to acknowledge the man's help....
  8. Your described symptoms are identical to what I was experiencing in my 2002 S with 39k miles. New switch cured everything.
  9. This is really a Great Write up! I used 11MM for the rear main seal and had a machine shop built one out of alum. No leaks yet with 6,000 miles the machine shop was short money! To be blunt catman......if I were to do it again......I would of bought the part from Pelican that installed the RMS...you have to factor in your time. I did not know it was available at the time I put together my homemade RMS tool.....JMO: http://www.pelicanparts.com/cgi-bin/smart/more_info.cgi?pn=PEL-TOL-P250&catalog_description=Oil%20Seal%20Installation%20Tool%20%28for%20original%2Dstyle%20seal%29%20%2D%20Flywheel%20Side%2C%20Boxster%2FBoxster%20S%20%28%31%39%39%37%2D%30%34%29%2C%20Each%20
  10. The Swepco works fine. Erik at Gbox (the transmission rebuild company) recommended the Swepco 201, Gbox knows their stuff so I took his advice. I had drained the original transmission fluid about a year back and replaced it with someone's recommendation of Redline products (Shockproof and another Redline lube) in hopes of helping the 2nd Gear pop-out issue, it didn't (No knock on Redline, my Tranny was past the help of lubricants). Good luck.
  11. I used these in the rear for clearance purposes: http://www.harborfreight.com/cpi/ctaf/Displayitem.taf?itemnumber=38847
  12. Hey Guys. I'm posting this up to share what I gleaned from my recent project on the Boxster. Last year I developed a 2nd gear issue in the tranny so I decided to pull it, send it out for rebuild, replace the clutch & pressure plate, replace the RMS and install the IMS retrofit kit. For step by step instructions and torque values refer to the Bentley manual, it proved invaluable. I did a bit of research for a few months before doing the work, in doing so I found some usefull advice and some not so useful, here is what worked for me: Getting the car up and ready: I put the car up on front ramps and 4 jack stands, plenty high enough to be able to pull the tranny out: Some people have said they were able to drop the tranny without removing the exhaust, it quickly became obvious to me that that shortcut was not going to work for me. I then removed the rear bumper and removed the B & B exhaust system. Having restored muscle cars decades back I learned that keeping track of bolts / hardware made life much easier during reassembly, don't forget the safety glasses either: Make up a board to keep the tranny to motor mounting bolts in order, there are several different sizes: Brace the motor for support before pulling the transmission, you can use an above the motor support bar, a jack stand or my method, scrap wood: I'm not an overly bright fellow, reminder signs help avoid disasters: I used a Transmission Adapter for my 3.5 ton floor jack from Harbor Freight which worked wonderfully (item # 95640): Use a strap in addition to the supplied chain to secure the tranny to the jack, you will likely have to pivot / tilt the tranny to be able to pull it out from underneath the car: If you are going to ship the transmission somewhere for service a 120 qt. cooler from WallyWorld ($50) is alot easier than making a custom wooden crate: Now that the transmission is off to Gbox time to deal with the RMS. Drill the old seal, screw in a self-tapping screw and remove with a pry-bar, worked for me: For the fun part; installing the new RMS. A fellow (Kyle AKA Shark Attack) on another Porsche board was doing the IMS /RMS job and looking for a way to install the RMS without the expensive Porsche install tool, I sent him this link: He thanked me and took the ABS coupling idea a step further, I basically copied his solution so I can't claim credit for coming up with this homemade RMS tool. Here is my version, go to Lowes Electrical Dept (not plumbing) and buy this plastic coupler: UPC / Part #: Then cut out a "floor" to be glued into non-threaded side and a "top" out of thin plywood. Glue the "floor" into the plastic coupler: You then need to build up the "center" of the wooden sandwich with a piece of wood which will give you the desired depth (13mm to 14mm depending on who you listen to) to drive in the RMS. After finding the correct thickness (as you can see in the pic, I used a piece of .035 paper to shim things up to where I wanted) glue them all up: You will then need to bore out the center flywheel flange / lip area along with drilling a hole for the pin so that the tool can seat itself flush against the rear of the crank. Seating the new RMS, all I can say is take your time and be patient (not my best trait). Now onto the IMS. I read everything I could; lock the motor at TDC, no you don't have to lock the motor, remove two tensioners, remove three tensioners, no you do not have to remove them but only loosen them ,etc. etc. Some guys had the IMS "jump" to the side due to remaining tension on the chains, some had to have their cars flatbedded off to the shop in order to get the motors retimed. I also read of a few nightmare scenarios where motors got smoked due to carelessness on the above. I contacted Jake Raby and asked what EXACTLY do I do, here is what he told me to do IN THIS EXACT ORDER: Lock the motor at TDC, completely REMOVE the TWO rear (flywheel side) chain tensioners (drivers side points directly out to the side of the car, passenger side points straight down), Remove and replace the IMS with supplied / purchased kit, REPLACE the chain tensioners and unlock the motor. From what I have read, the BIG problems occur when people rotate the motor after the chain tensioners are removed, DO NOT DO THAT. The other BIG problem occurs when people remove the IMS cover without removing the tensioners, DO NOT DO THAT either. Locking the motor: remove the engine access cover, rotate the crank (CLOCKWISE) until you see the notch A in the rear of the crankshaft pulley. Match up that notch with the cast in hash mark B in the block at around the One O'clock position. Now use your Porsche locking tool or make one out of 5/16" metal rod (I used some scrap allthread) cut to 3" in length, insert it into the hole in the pulley near the 11 O'clock position C. You should be able to feel it go into a recess thus "locking" the motor. Try to turn the motor over by hand just to ensure you cannot. R & R of IMS Bearing: This was actually the easiest part of the project, follow the supplied instructions, a few videos: http://www.youtube.c...h?v=9lm2N-HlA1k The only tip I can give on this is to use two mallets (one rubber, one dead blow) for bearing insert due to interference from the crossmember. After getting the replacement IMS bearing partially in, place a rubber mallet on the Aluminum install tool and use the dead blow on it for more square / direct hits, you don't have to use much force. A palm sander and abrasive discs clean up the flywheel nicely: Filling the transmission prior to install makes things a bit easier also: For that problematic bolt located at the top of the tranny, wrapping a universal joint in duct tape barely catching the lip of the bolt holding it in place and ganging every extension you have (mine came up to nearly two feet) makes life a bit easier: Good Luck Guys.....Mark.
  13. drag: Pedro's Garage sells these mounts in two versions, but you apparently have to be prepared for a little more vibration because the flexane is less flexible that the rubber of the OEM mounts. It may be ideal for tracking. You can certainly make your own, all you have to do is buy the flexane. There are a number of online dealers that will sell you the flexane, and some even offer different "hardnesses" . Regards, Maurice. Anyone have the 'enthusiast' mount? That's the one I have on order. I hope it's not too vibrating...... P I ordered and installed the Enthusiast Mount last month. Follow the DIY instructions on Pete's board and you will be fine, pretty straight forward. There is more vibration, especially around 3,000 RPM, nothing obnoxious though. Good Luck.
  14. I also have a need to replace one of the rear bulbs. Are these items readily available at NAPA, Autozone, etc. or dealership / internet only?
