Click here to Donate
awssvtt
Everything posted by awssvtt
  1. Try 6483 or 6381 Hi Loren, I tried both but it did not worked. I am able to obtained additional info; R3297 W 5011 804 Many thanks, Linh
  2. Hi Loren, May I have the code for Becker CR-210 BE 2182 Serial Number W 5011 804 Many thanks, Linh
  3. Hmm... my program says 8368 also. Is that the code that is displayed? Yes. The serial number was obtained utilizing your instruction. I just entered 8368 once and then push the signal seeker. Is this the correct way? Thanks, Sean My mistake. Just read the serial number again and I erronuously missing a 0. The serial number should be S 5000 150. No wonder the previous provided code 8368 did not worked. May I have the code for S 5000 150. Many thanks, Sean
  4. Hmm... my program says 8368 also. Is that the code that is displayed? Yes. The serial number was obtained utilizing your instruction. I just entered 8368 once and then push the signal seeker. Is this the correct way? Thanks, Sean
  5. I needed your help. Went to the dealer and was able to obtain the code. Code provided from dealer 8368. Tried 3 times and did not worked. Still got "CODE ERR". CR-210 R 2095 Serial Number S500150 Many thanks, Sean
