insite
Everything posted by insite
  1. john - do you have aftermarket toe links? i was aligning my car yesterday and am unable to run less than -2.2 deg camber in back and still meet my toe requirements. at -1.8 in back, i can't get less than 13/16 toe in (the left side is at max out). i do run RoW ride height, but i didn't think that would matter so much....
  2. interesting. i've never run more positive than -1.5 in back. i've got staggered tires, too, but i bought them from a 996, so they're 225/265. how do your tires wear with that little neg in back? the track i go to most often has few transitional turns compared to many steady state sweepers / carousels, so maximizing lateral grip is a must to be fast there. where do you usually drive?
  3. The car is set up for minimum rear camber and zero rear toe. To acheive zero toe you set the toe adjusters to as low as they go and then dial in negative camber until the toe actually reaches zero. If you were to set the camber adjusters to "max positive" rear camber (about -1.0 to -1.2 degrees) and then set the toe you would not be able to get out all of the toe-in. Make sense? :) To string the car we set the strings to be parallel to one another, then measure how much the car is misaligned between the parallel strings and adjust the strings (equally on each side obviously) to compensate. That leaves you with parallel strings and a car which is parallel to them. i usually use two plumb bobs at the midpoints of the sway bars (as measured from the control arm mounts). i then use a laser straight to strike a centerline. i measure to the centerline from the toe plates to get toe. as for camber, it seems odd that you're only able to get -1.0 to -1.2. maybe i'm misunderstanding. isn't the factory setting between -1.6 and -1.8? why are you running minimum rear camber? acceleration (auto-X)? just curious as to why people do what they do. i was running about -2.0 in back and -1.6 up front most recently. this proved to be too much neg for street tires; they actually wore on the insides at the track. this time i'm going to run -1.2 up front and -1.9 in back. i'm going for 1/16" total toe (slow track, < 110mph). i'm going to try toe out (1/16") for the irst time up front.
  4. wow; good to know. maybe i just got lucky; 5/32 is a lot. why are you toed all the way out in back? is the car lowered a lot? tarrett arms? out of curiosity, when you string your car, do you just do parallels on each side of the car, or do you use a center line for thrust angle?
  5. 1. remove calipers from your car. don't push pistons back in. 2. open bleed screws and pour out excess fluid 3. use two screwdrivers to pry each piston out of its cylinder. 4. remove inner seals w/ plastic covered paperclip to avoid scratching cylinders. 5. clean all parts w/ 99% rubbing alcohol. this will dissolve the brake fluid. 6. powder coat calipers at this point if desired. 7. soak new inner seals in brake fluid for 30 min. 8. install new inner seals into calipers. 9. coat inner ring of each outer seal with silicone grease. 10. slide an outer seal onto each piston. 11. lubricate each brake cylinder with a light coat of brake fluid. 12. begin pressing the piston into its cylinder by hand until you hit the seal. 13. twist the piston slightly as it passes the seal 14. once past the seal, seat the outer dust boot in its groove 15. press cylinder all the way in. use a long piece of wood if you need some leverage. 16. repeat for all pistons. 17. install calipers and bleed system. to do this job you will need inner seals AND outer dust boots. the outer dust boots are about $10 a pair from Sunset Imports. the inner seals are about $13 each from HRP World. don't do this unless you're sure you need to. you likely have no problem with your calipers unless you track the car.
  6. that is VERY strange. i wouldn't think it would break unless something else in the engine siezed first. which chain was it, IMS side or oil pump side? my first guess would be maybe some debris in the oil pump locked up the pump and the resulting stress snapped the chain.
  7. the M030 sways are great with the stock springs. they are also quite comfy (they passed the woman test). the H&R will be way too stiff if you like the current ride; they're more geared toward motorsports. eibach is similar to the M030. i recommend the 'S' M030 front bar (24mm) and the base M030 rear bar (19.6mm). they are cheapest from Sunset Imports (around $215 for BOTH sways and BOTH sets of bushings).
  8. yeah, PCA DE is tough to get into at RA. there is a DE coming up in September at Roebling Road that's a lot easier to get into. i'll be going. I may also do RA in october. i've never done a NASA event. probably next year. i'm getting to the point where i want to / am able to do a lot more driving...
  9. you want to do both front calipers. you will need four 40mm seals and four 36mm seals. if you do the rears also, you'll need 4 x 30mm and 4 x 28mm seals. they're on this page: http://www.hrpworld.com/index.cfm?form_pro...;action=product use 99% rubbing alcohol to clean out the calipers (it dissolves brake fluid & doesn't leave moisture or residue). soak the seals in brake fluid for 30min before installing. use high temp moly assembly lube on the pistons when you reassemble. put the outer dust boots on the pistons BEFORE you put the pistons in the calipers. the new surface at RA is great. i primarily do PCA and private events; no W2W stuff until i have a larger budget.
  10. also, if you get a chance, remove the dust shields behind the rotors. this is good to do when replacing wheel bearings. they'll cool better.
  11. you can get the inner seals from HRP world. they're $13 each. usually it's those that go; they overheat. they're only designed to take 400 - 500F of heat at the seal. there's a thermal barrier coating on the pistons that helps prevent this, but on the track it can still happen. once the seal has been overheated, it won't retract the pistons properly. the result is that the pads drag slightly and overheat the pads / calipers, causing fade. replace the inner seals in your old calipers and they'll be fine. if you haven't moved to a full race pad yet, do so. you will be suprised at the difference. it's more economical to keep a street set and a race set if you go to the track a lot. i like hawk HT-10, pagid orange, and carbotech.
  12. that's definitely the way to do it. i've done several of these and never removed the axles. it's actually possible to split the ball joint and still remove the strut assembly with the axles and lower control arm in place. it's FAR easier, though, to remove the entire lower control arm and leave the ball joint in tact. three hours must be some kind of record! the best i can do is four, but that's just one man. Yeah, after doing it this way I can't imagine why anyone would remove the axles, calipers, etc. I did the front without cracking the ball joints or control arm or caliper as well - but it's kind of a wash as to whether that method is easier or not. i think the fronts are much easier to remove without splitting the ball joints. no risk of ripping a boot, either.
  13. that's definitely the way to do it. i've done several of these and never removed the axles. it's actually possible to split the ball joint and still remove the strut assembly with the axles and lower control arm in place. it's FAR easier, though, to remove the entire lower control arm and leave the ball joint in tact. three hours must be some kind of record! the best i can do is four, but that's just one man.
  14. this is partially true for the toe eccentrics, but not the camber eccentrics on the lower control arms. i have a SmartCamber guage that i use to verify camber after this type of work. i've had the rear control arms removed four or five times. if i set the eccentric to its previous position, the camber doesn't change at all.
  15. you'll still get a lot of benefit just from doing the sways. optionally, you can do the complete U.W. M030; it doesn't change the ride height.
  16. awesome, isn't it? the compromise in ride quality is almost unnoticable. i really think it should have come standard like this.
  17. it would depend on your toe value before you moved the camber. if you have a toe setting that's within spec, max neg camber up front will decrease your front toe-in. this is generally desirable for auto-x. it MAY even push you to toe out up front, which many people also consider desirable for auto-x. just try it and go for a drive to see how it feels. you'll know immediately if you've gone too far.
  18. it's a friend's guage. you can get them from smart racing products. you can also make one with a level from home depot, but it's kind of a pain. as for toe, i do have toe plates that i use from time to time, but my alignment guy only charges me $60 for a four-wheel, so i mostly just take it to him. changing the toe up front is easy. measuring it in accurate relationship to everything else is tougher. BTW, everyone says that changing the camber on these cars also changes the toe, and it does. i've found, though, that the front toe is particularly insensitive to camber changes, so i can change my front camber a lot without changing front toe much. for me, i have it set up so that when i set the camber to my track setting, front toe goes to zero. when i set it to street, toe goes in slightly, which is desirable for street driving.
  19. the 1lb kit was enough for me to do my motor mount, all four control arms and two strut top mounts. also, you don't remove the factory rubber. you clean it with alcohol and cast the flexane around it.
  20. correct. ebay has tons of them; do a search for volkswagen transmission drain tool.
  21. why would you do that? my point is that the base calipers ARE the S calipers. the only difference between the two is how the pins are set (as above). so, you can use either caliper on either car with either rotor depending on how you set the pin depth. the only benefit the rear brakes on the S have over the base is that the rotors are thicker. if you wanted to use these thicker rotors on your base boxster, you would need to buy the rotors described by JFP in PA in this thread. you would then need to set the pin depth on your calipers to accept the thicker rotors. that's it. no need to buy new calipers. also, one more time for clarity: this only works on the rears. the front calipers are different in several more ways.
  22. fantastic news. i am really glad to hear that. thanks again for your help!
  23. they're not on any diagrams. they're supposed to be part of the caliper. you can remove them and re-insert them to a different depth.
  24. i'll try to explain. the caliper mounting distance from the hub for the S and base rear calipers are the same. the caliper offset (distance from mounting point to the center of the pad clamping area) are also the same. as are the cylinders, pistons, etc. the ONLY difference is the mounting position of the pad retainer pins. the first photo shows the pins i'm talking about. The second photo shows an S caliper pin from the outside. notice the pin is flush with the caliper surface. The third picture shows a red base caliper's pin mounting depth. it's mounted deeper than the S caliper's! the final picture shows the roll pins that retain the caliper pins in place. now for the cool part: the caliper retaining pins for both calipers are the same! that is, they can be mounted at either depth. one can simply remove the roll pins, slide the caliper retaining pins in or out, install new roll pins, and convert the caliper! that is all. the base caliper's pad retaining pins are installed in the narrow position so that they won't fit around an S rotor, which is thicker. the base rotor is identical in diameter and offset, but is 2mm thinner. so, an S caliper can be installed on a base rotor, but a base caliper can't be installed on an S rotor without the above mentioned modifications. i took all measurements of an S caliper and a base caliper to prove this; all dimensions are identical except for the pins! crafty, eh?
  25. stay tuned for pictures on how to turn an S rear caliper into a base rear caliper and vice versa. BTW, the base rotors will work with the S rear calipers. i will post pics on how / why this is the case. i'm thinking maybe brembo sends you cross drilled base rears. next time you buy a set, measure the thickness. i bet they're standard thickness. i'll post the pics / measurements / explanation a bit later; still messy from working earlier.
