shvt
Contact Methods
  • Website URL
    http://
  • ICQ
    '01 996 C4 Cab
    '06 BMW 650i
shvt's Achievements
  1. The rear window does the same thing with the top down and front window down, so there would be nothing stopping it. It's odd because it just started doing this. I have the SmartTop and RemoteTop that enables me to close all windows and the top with the touch of a button but now that one window goes back down a bit.
  2. I was wondering if there is a such thing for Porsche. I know you are able to do this with some BMW's. I have a cabriolet and the driver's side rear window would close and go down 1/3 of the way as if someone stuck their hand in between the windows. If this issue has already been brought up before, I apologize. I have searched and searched with no answer. Thanks in advance.
  3. I just got the JIC coilovers installed on my '01 996 C4 Cab and am bumping into some problems, no pun intended. I have it as low as the adjustments will let me go without adjusting both the springs and the helpers, which is really 1 finger gap in the front and a tiny bit higher in the rear. It was initially set to the middle dampening. It was way too rough for the roads around here, 10 freeway in Los Angeles. I ended up turning it to full soft all around. It rides fine on some roads but I have a problem with driving on that horrible freeway. The front bounces like crazy and I see my head lights going crazy. I would hate to be the driver in front of me. I know my alignment is way off because everytime I hit a bump, the steering wheel would jerk left or right. I am waiting for another week for my springs to settle before I get an alignment. Will the alignment help this problem? Should I not set soft all around? I am looking for comfort. Thanks in advance...
  4. Try 3146 or 3144 3147 worked for me. Thanks Loren...
  5. Loren, I need the code for my radio as well... Model 220 Serial Y5025355 Thanks in advance...
  6. I've tried searching and can not find an answer. I do not have the manual (just got the car and no manual available) and tried reading the downloaded manuals with no luck being able to find out how to correct the gauge reading. Can someone please post what the manual says? I have an '01 C4 Cab. Thanks in advance...
