jrose
Everything posted by jrose
  1. I'm installing a CDR-220 from a 2002 Boxster in my '89 911. I've even purchased a "modified controller" from Becker so I can see the display. I also intended to install a Haes amplifier from a Boxster, but the one I purchased on eBay did not come with the two connector plugs--one big, one small. I've called Becker, but they could not help. I have the plug that will connect the low level output of the radio to the amplifier, but that's all I could get from Becker. An audio shop I contacted says the two plugs--or perhaps a whole harness--is available from Porsche. I checked my PET program but could find no information (illustration, part numbers, etc.). Can anyone help?
  2. I have mine in the lower right hand corner of the windshield in my '89 911 Targa.
  3. Just another thought that has occurred to me. I've also seen ignition coils fail when warm but work OK upon initial start-up. Do you have spark immediately after the engine stops running when warm? If not, you might want to try substituting a coil known to be good. Also, back to my first thought on this problem--the head temperature sensor or sensor II as Porsche calls it--when the engine is thoroughly warm (when yours seems to die), you can disconnect the sensor plug in the engine compartment and check the sensor's resistance to ground with an ohm meter. With a fully warmed engine, the reading should be about 90 ohms. A working temperature sensor's resistance will go from high (making the mixture rich) to low (leaning the mixture out) as the engine reaches normal operating temperature. If yours remains high when warm, you have a faulty sensor. Hope his helps.
  4. If you note that the engine is running rich (black smoke, etc from exhaust) when the bucking begins, you might want to check your head temperature sensor. Just an idea, of course, but those things do fail.
