venturawildes
Everything posted by venturawildes
  1. 2002 996 Cab I just replaced my pass side regulator, the tip about the hair dryer on the foam liner was spot on. Now my check airbag light is on, I am sure that I plugged it back in, does any one have any suggestions on this one? I turned the key on when the airbag was unplugged. Thanks Joe
  2. I went with the Sumitomo HTR Z II's $550.00 delivered from tirerack, I asked around, my buddy has them on his Boxster, a guy at work has them on his 996. I do not pitch my car into corners, mostly just cruise up and down the coast, it is a daily driver, I just couldn't pay 2X for N on the side of the tire.
  3. I am in the midst of changing the pass side regulator, can someone dechipher this for me? Disconnect (3) the bowden cable (arrow and electrical plug connection - Disconnect electrical plug connection from the microswitch for the door handle 9 and orientation lighting 10. Press lugs of the plastic clip (arrow A) and pull out towards the rear. Carefully push the bowden cable 8 back into the end piece of the sleeve. Where is this at? Is there any way some one could post a pic of this? or point me to a pic if already posted?
  4. Hmm, don't really know if i would want to open the top while moving. I cannot believe this car, I am stunned, it is engineering porn.
  5. Loren, is the sealing material the buytl cord or the film?
  6. Loren, you are amazing, thank you. I will post a pic of the other part when i get home.
  7. hi there, I still getting to know my 2002 seal grey cab, I love it. One question, right now the top will only lower if i am stopped and the parking break is on, is this normal?
  8. Hi there, I am replacing the pass. side window regulator and need to know the part number for the thin plastic film for waterproofing, sometimes called foam (actually don't know if it is plastic or not, it is the one that everyone cautions to be careful removing, held on with buytl). Also if there are any other items I should replace like the plastic tabs that hold the door panel on please let me know also. I also need the battery cover, washer for the spare tire holddown, and the little lens that goes on the little hold down area for the top, the place when the latch pulls the top down, it's about an inch long, half inch wide, one on either side. 2002 C2 Cab, seal grey, US model Thank you
  9. Does any one know if there is a difference between Perelli P Zero Rosso Aysmetrico N spec Vs Perelli P Zero Rosso Aysmetrico? Are they the same tire? Why is the N spec 80 bucks more expensive?
  10. 9039 worked, Thank you very much. Try 9039 or 9037 If you have not already read this FAQ - please do so... Lost Radio Code - FAQ, PLEASE READ THIS FIRST
  11. Hi there, I need a code for 2002 996 Becker 1 CR220 4362 25007849 24/99 Thank you
