jhae
    986
jhae's Achievements
  1. make sure you are have taken the right plug out as there are two and can be easily mistaken the one you need is the thick one that stands out. failing that you will need to remove your wheel and wheel arch liner and manually relese the light ok so if i remove the wheel and liner how do i get the light out just push it forward? or...????????????????
  2. ok guys i have a big problem today i tryed to remove my headlight and noticed that the bolt in the little hole you put the tool in isnt there what do i do now? my driver side has it but not the passanger? is there any other way to get it out?????// any help would be greatly appreciated thanks in advance
  3. hey guys just to let all of you know this store on ebay sells bosh maf's for 199 heres the link http://stores.shop.ebay.com/Mercedes-BMW-L...c0Q2em14?_pgn=2
  4. hey my car has the same problem with just about all your codes did you ever find a solution my car was running like shi* then i cleared the codes and wont run at all starts runs super rough then cuts off
  5. ok lost my code heres the info type 4462 15064965 hopefully you can get me the code and save a trip to the dealer thanks in advance
