geeklife
Everything posted by geeklife
  1. If the code works, what happens? Does the radio work right away? I tried both codes and it doesn't seem to have worked. Even got the "wait" code and had to wait an hour. Tried the codes again and keep getting prompted to enter again. How many times should you enter the code? Thanks for the help. PLEASE - read the FAQ. Follow the instructions in the FAQ. Still didn't work. I called the dealer and obtained a code from them as well. Still didn't work. Seems if no codes work on the radio, then the radio itself, per the dealer, is defective. So, looks like I need to replace my CDR 220. Thanks for the previous help and posting of the FAQ. Did you get the serial number through the radio display? Many times a tech changes out a radio and forget to change the code ID card too. Yes, I got the serial via the radio display. Followed the instructions on the FAQ =)
  2. It's solid black and is plastic. Thanks much.
  3. Looking forward to your ebay listing. Definitely interested.
  4. If the code works, what happens? Does the radio work right away? I tried both codes and it doesn't seem to have worked. Even got the "wait" code and had to wait an hour. Tried the codes again and keep getting prompted to enter again. How many times should you enter the code? Thanks for the help. PLEASE - read the FAQ. Follow the instructions in the FAQ. Still didn't work. I called the dealer and obtained a code from them as well. Still didn't work. Seems if no codes work on the radio, then the radio itself, per the dealer, is defective. So, looks like I need to replace my CDR 220. Thanks for the previous help and posting of the FAQ.
  5. Looking for part number for 2001 Boxster passenger side air vent.
  6. If the code works, what happens? Does the radio work right away? I tried both codes and it doesn't seem to have worked. Even got the "wait" code and had to wait an hour. Tried the codes again and keep getting prompted to enter again. How many times should you enter the code? Thanks for the help.
  7. Need help getting a code too. Here's our info. Becker 1 Type: 4462 Serial# Y5038582 24/99 2001 Boxster base Thanks much
