BMiller33
Everything posted by BMiller33
  1. Check the wires beneath the airbag on steering wheel; mine had frayed and came loose. I spliced a new connector and was good to go.
  2. My horn issue ended up being the wire beneath the air bag on steering wheel. It had frayed at the connector and was hanging loose. I simply spliced a new connector and all was fixed.
  3. My 03 996 TT has the following issues: 1. Horn sometimes works sometimes doesn't. No issues going over bumps etc 2. Airbag failure light recently came on but I believe it is my fault, I had drivers side seat out as I was doing some under dash work unrelated to the horn. I plan to check connections etc for the airbag Q. can these bushing also be the cause of intermittent horn operation? Q. is it possibly my clock spring is malfunctioning causing horn and now airbag light? Any other recommendations? Thanks in advance.
  4. Old thread but worth updating. There are 2 tabs for the air vent removal, they are on either side of the center. Go through the second louver so you can get a good angle. The tabs have a small rectangular hole you grab with the corner of a flat end screwdriver and pull down as you are pulling out on the vent. Do RH side first then do LH side to fully remove the vent. First time is PITA but afterwards you will see its fairly easy. Flashlight is your friend.
  5. I completed the project and posted step by step on 6speed if anyone is interested. http://www.6speedonline.com/forums/996-turbo-gt2/305304-refilling-spoiler-hydraulic-ram.html
  6. I've yet to figure out how to add fluid to the ram. I have removed the leaky ram but when I place it upside down to fill it as per the service manual I'm lucky to get anywhere close to 1ml, let alone the 5 specified. I used a syringe but no fluid goes into the ram (it is fully retracted, as if when it was on the deck lid the spoiler would be down). Please help. Secondly, after this, do I need to bleed the entire system? Thanks in advance.
  7. I wish it were only $60; they sell it now for a whopping $179!! See their ebay link below. http://www.ebay.com/itm/PORSCHE-TRANSMISSION-996-BOXSTER-NEW-UPGRADE-POP-OUT-2ND-GEAR-DETENT-/160784555848?pt=Motors_Car_Truck_Parts_Accessories&vxp=mtr&hash=item256f819f48
