weewinn01
Everything posted by weewinn01
  1. radio 220 serial 15085645
  2. I have a 2006 987 and the problem i'm having is that the one touch up is not working on the drivers side. The passenger side works up and down no problem, but the drivers side will only work with down one touch, no up. I've also noticed that the window will drop with when pulling the outside handle, even with the door open on drivers side, which isn't suppose to. also when closing the convertible top the drivers window will not close automatically, it will drop when you open the top but will not close when you close the latch. I've replaced the door latch assuming the microswitch on the latch was bad, and the switch on the outside handle seems to work because the window will drop when pulled but will not go up. please help this is killing me that I can't figure it out
