teamwenz
Everything posted by teamwenz
  1. I second the Wheel Enhancement endorsement. They have treated me well on my purchases.
  2. My local dealer gives a discount on parts if you are a member and usually one part purchase pays for a year's dues. So it's a no brainer plus all of the other benefits.
  3. Thanks, will probably happen during a track day as well
  4. I was recently driving in a spirited manner hard brakeing and cornering and my PSM off light came on. The PSM system did not engage to my knowledge or ABS. I tried the switch on the dash and it did not switch the system back on or did the indicator light work on the switch. I cycled the key off and on and everything works fine again, switch on dash worked again. I know the PSM system works because I have had it engage recently. Any thoughts...
  5. Used a mount from MTG Motorsports. A little pricey but an excellent piece. And thanks for the heads up on the plug in the console. I pulled the panel off and there it was. The only thing is the a pillar pulls out and not straight up when you remove it. There are two metal spring tabs that need to disengage before you can remove it. Now I have a hard wired Escort 9500ix. Thanks again for everyone help.
  6. I was recently driving in a spirited manner hard breaking and cornering and my PSM off light came on. The PSM system did not engage to my knowledge or ABS. I tried the switch on the dash and it did not switch the system back on or did the indicator light work on the switch. I cycled the key off and on and everything works fine again. I know the PSM system works because I have had it engage recently. Any thoughts...
  7. I have 98,000 miles on my car and the clutch is about half worn out.
  8. Just finished taking an inlaw to brownsville TX from WI and will be flying home. 1625 miles in a 2006 Camry, man it was painful. Boy I miss my Boxster. Six states and the only other Porsche I saw was a blond in a Cayene outside of Austin TX. 80 miles an hour most of the way and averaged 26 mpg. I sure dislike Japenese cars and miss my German ones. Overboosted steering and marshmallow suspension.
  9. The unit can't draw much power. I have PCM on my car. I would like to keep wires as short as possible as well. Hmmm
  10. Can you use the doom light for power to a windshield mount escort passport 9500 ix. If so how do you get at the power wire in the dome light?
  11. 2001 Boxster S CDR 220 4462 Y5047400
