70Sixter
Everything posted by 70Sixter
  1. Yup, ya mighta got up too early. I guess you already ruled out expanding your garage or building a new one for some really good reason? <_< Good luck with the garage!
  2. Jim's right about the gas, but add Stabil also.
  3. Dental floss works to remove the logo. Just work it back/forth with some pressure. P21S will take the remaining adhesive. At least if it has not baked too long in the sun before removing the logo.
  4. I think I found the phone connector under the storage shelf of my 04 986S while looking for a radar detector power connection. It has hot, ground, mute, and (I think) keyed hot. I read http://www.renntech.org/forums/index.php?s...c=6046&hl=cdr23. And http://www.renntech.org/forums/index.php?showtopic=5190 which is for a CDR-220. Becker lists "Telephone power cable, 5001.524-276 and CDR-23 Phone input cable is BNA-116.276 ($17.00)." Haven't heard back from Becker on whether you need both. Local Becker dealer clueless. The 5190 post also specifies Audio/telephone cable kit - p/n 1319.116-276 - $16.00. Is this for analog/non-MOST applications? If anyone can clear my cobwebs on hooking up handsfree cell phone that will put audio over speakers I would very much appreciate it...........Thanks,,,,,,,,mike :help:
  5. My 04 S has only been cold (< 30) once - left out at night at dealer's. Check engine light even came on. Then went out when warmed up a bit. Dealer said it was common, and that "Porsche was working on it."
  6. I recommend Suncoast. http://www.suncoastporsche.com/ mike
  7. I just installed smartTop 986 in My 04 Box S. Easy install. Works great. Cannot believe how much it means to not have to set the handbrake.
