deilenberger
Everything posted by deilenberger
  1. I'm frustrated. I stopped at our friendly local Porsche dealer on Saturday hoping to pickup touch-up paint for my '06 Cayenne/S - Titanium dealy.. which is in "Iceland Silver" according to the VIN readout.. and they couldn't find a listing for the paint. I looked myself in PET, and I can't find a listing for it. Anyone know what the paint code is? Or a part#? Thanks much! Don Eilenberger
  2. Folks, I "won" (buy it now) a CD changer from Ebay.. It was from an '04 Cayenne, and has PN: 997.645.140.03, and Version PA149D. My Cayenne is a late production '06 with the Titanium package. According to PET - this should work with my Cay. My question is - I have the PCM 2.1 - will I have to "activate" it in the PCM before it will work? Looks like all the cables are in place (the Cay has CD-Changer "prep") and I'm hoping for Plug and Pray.. TIA (not a single response on RENNLIST - go figure. Doesn't anyone do their own tinkering on Cayennes? (I'm from the BMW community, where hacking, modifying, fixing your own car is all the rage.. but perhaps the X3/X5 owners are not quite as DIY as the ///M-car people.) Don Eilenberger
  3. I'm VERY leary about something that has as much magic attached to it as SeaFoam. The other difficulty I see - I didn't see a vacuum line running to the TB, although there could be one. The ease of getting to the throttle body (especially if you do it while doing an air-filter change) makes it a no brainer for me to do it the right way, with carb-cleaning solvent on a rag. I opened the butterfly on the TB, and held it open with a soft-handle screwdriver handle so I could clean the backside of it and the area of the bore past the butterfly. Once you know how to remove the Y intake pipe (and I didn't remove it entirely since the hose on the bottom didn't want to unclip - I just moved it out of the way) - the rest of the job takes about 5 minutes. Next time I'll take some photos for a DIY..
  4. I think it will become part of the replace the air-filter process for me.. Be much easier to do both at the same time.
  5. wvicary, After about 20 stops and restarts (we went out trucking today in our local national park) - it's fixed! Started flawlessly each and every time. That one suggestion made membership cost for this forum insignificant. MUCH happier with the Cayenne now! Thanks much!
  6. I cleaned the TB this AM (and it is easy, once I found the page showing the positions of the lock-goobers for removal of the intake Y plumbing, the Ebay manual I got has 9980 pages.. luckily Acrobat is pretty good at searching.. :) ) but - I digress.. It was certainly not awful. I did dirty a rag (used carb cleaner on the rag rather then spraying it) on it, so there was some stuff. It seemed to start fine after that, but that was only one try. Will update if this improves things. Also have new plugs arriving sometime this week (56k on the ones in there as far as I know..) so I'll be installing them. Thanks for the nudge toward the TB - certainly worth the try, and I'll update the results after a few more cold starts. Don
  7. I think you're absolutely correct. Looked at it again as I was cleaning the throttle body - and there is no way to see down through the intake assembly. Bummer. Thanks!
  8. wvicary, Interesting on the throttle bodies - and doesn't look difficult to do since the TB appears to be right up front. No idea on engine codes yet - no OBD-II codes are stored, but awaiting my Porsche specific tool.. The service was done by a dealer. They've promised to give it to me, I just have to get there when the service department is open. The pumps haven't been touched since the carpeting hasn't been cut. Thanks! Don
  9. Just curious - somewhere there is a thread on how to identify if your Cay has the aluminum or plastic pipes.. and it involved removing the rear plastic body cover and perhaps the auxillary air pumps, and using a mirror and/or camera to try to see that end of the pipes. I tried that with an amazing lack of success. Today I was poking around my '06 using a CSI flashlight (Maglight-tm) - and noticed that if I look between the intake runners on the top of the engine, I can see what appears to be a large black plastic pipe. Doing this was MUCH easier then the contortions required for the other method. I've gotta get my camera out and take a few photos.. but I *think* you can see the plasic pipes with the use of a bright flashlight without any contortions required. Just a FWIW, and mebbe I'm all wet (well - not yet, but I do seem to have the plastic pipes..)
  10. I see a lot (well enough) people replacing fuel pumps on their Cayenne's.. My '06 S exhibits a bit of lean start.. by that I mean when cold it takes longer then I'd expect for it to catch when cranking. It also has a very slight hesitation when gently accelerating and it's in a higher gear. It has no lack of top end, and no lack of power - which to me means it has adequate fuel supply for the engine's needs.. but it's been suggested to me it could be fuel pumps. Questions: - Anyone else have these symptoms? - If so - any resolution to them? - If it involved fuel pump replacement, was the fuel filter replaced at the same time? - Anyone try JUST replacing the fuel filter? The reason I'm asking - the positive displacement type fuel pump gets unhappy run dry (since fuel is used to cool it) and unhappy if there is backpressure - which can be caused by a plugged fuel filter. I find it hard to understand putting the filter in the tank where it's extremely difficult to get to (most vehicles have it external) - so I'm guessing that when Porsche replaces the pumps, it's probably automatic to replace the fuel filter. There are other possibilities for the lean start: - BMW M3's ('01-06) have this happen every spring as the east coast fuel mixtures are changed to summer blend. Apparently the stuff is different enough that the car isn't that happy starting. It frequently can and does take two cranking sessions to start them. Like swallows returning to Capistrano - the M3 forums are regularly deluged in the spring with people asking questions and complaining about this behavior. It seems to go away about September. - BMW was replacing fuel pumps for this on cars under warranty - with the claim that the check valve in the fuel pump (that maintains pressure in the system when the car isn't running) was allowing the pressure to bleed off. The test was an overnight pressure test (put the gage on before the mechanic went home at night, then check it again in the AM - more then some BAR number loss was considered new pump time.) - Anyone checked the fuel pressure on the Porsche? The manuals want 2BAR - but didn't give a bleed off time test that I could find. It appears from the manuals that the check valve is in the top mount to the tank for one of the pump assemblies. Dunno if that part is available separately. Or is the lean start condition just normal on these engines with certain fuel mixes..? Lots of questions.. but that's the only "problem" I can find with my new to me Cayenne, and it will bug me until I resolve it, or decide it can't be resolved and "they all do that.."
  11. One comment - to help keep from breaking the plastic - make it easier to operate. Spread a dab of grease on the locking bar where it turns up and grabs the headlight. I also put a bit of teflon grease on the slide rails for the headlight.. but that might be unnecessary. The locking bar treatment made it much less effort to have it click into the locked position.
  12. FWIW: Best price I found on the V8 Bosch OE (FGR6KQE) plugs: Permalink: http://amzn.com/B002PCG07S - Amazon. $8.77/each (they were actually a bit cheaper last night when I ordered them..) Worth keeping a link to them. And NAPA (auto-parts places catering to small garages) has replacement coils - ECHLIN brand. Dunno how good/bad they are, but how much worse could they be then the ones that Porsche is selling? Takes a bit of searching, but they'll turn up.. http://www.napaonline.com/Search/Detail.aspx?A=ECHIC643_0211118455&An=599001+102006+50062+2062014# - for the V8's, $20! http://www.napaonline.com/Search/Detail.aspx?A=ECHIC611_0211118458&An=599001+102006+50062+2062014 for the V6 - not as good a deal. NAPA also seems to show what looks like the right plug (it has the same 7413 PN reference as the Amazon plug) - but no price on line, can only be purchased from the local stores: http://www.napaonline.com/Search/Detail.aspx?A=BSA7413_0311871967&An=599001+102006+50062+2062014+4062005+5999999+503001+503499
  13. Anyone have a PN for the harness(es) needed to install a 955-044-900-12 CD-Changer on a Bose equipped S? Thanks!
