B_P
Everything posted by B_P
  1. Thanks, I'll order that and give it a try. I'll keep you posted. :wrench:
  2. I purchased the Sealing ring, but i cant figure out where it goes, i can only find it referenced in the V6 engine. #32
  3. Is there a Part number for the seal, or do you have to purchase a new cap?
  4. Thank you for the diagrams, I checked the Filler Cap and it appears to be on tight, I also replaced the turbo breather pipe that is located behind the manifold (part number 948 107 215 52) becuase that was broken. I can't seem to find any other leaks in the system. I dont want to keep replacing hoses if they are fine becuae those hoses are much more expensive than they should be... but its a Porsche so it doesn't suprise me.
  5. So I am getting CEL of P2189 i have a 2005 Cayenne Turbo and i know it is related to: Possible fault cause - Incorrect main charge signal - Intake air system leaking - Fuel pressure too low - Volume supply of fuel pump too low - Mechanical fault in injection valves - PCV valve leaks - Cap of oil filler neck leaking - Leaks in exhaust system - EVAP canister purge valve mechanically faulty (hangs open) - EVAP canister purge valve output stage faults Would it be possible for you to post a diagram of where these are located on the engine and part numbers? I think I could fix it from there if I just knew what I was looking for and where its located. Thank you so much!!!
  6. When tightening down the bolts, when putting the engine back together, what was the torque that you set them to? Thank you!
