ekstroemtj
Everything posted by ekstroemtj
  1. @JFP in PA thank you. So the specs for oil are given. What i can do change the oil more often using high octan gas because thats bringing down the combustion temp too cutting some slices into the hood to get a air scoop for better fresh air Access (i was really thinking about it :-)
  2. Might the sort of oil we are using and the interval we change it have some impact of operation temps with this engines?
  3. @PkcayenneThank you for writing. I will check again carefully for splits
  4. I am in the same boat now. The bad thing, i am 1000 km away from home. Why this kind of things need to happen always far from home. I inspected all tubes like explained here. Couldnt find a crack. The brakes are behaving as usual. Until now. I have to drive back 1000 km. What to do? Any idea? Thank you
  5. You really deserve a good end of this story. The rumbling and vibration will be gone and you will see its a big big difference
  6. Thank you Lewis. On the passenger side is sitting the fuel pressure regulater?! Should i get a new one? about the bushings, i used some kind of rubber care like shown below
  7. I will need to change my passenger's side fuel pump. The other one on drivers side should be already replaced according the shop. I would like to try to do it by myself. Does anybody know if I need to open both sides of the tank or is one enough? Thank you Second question is touching my suspension. I didn't have any noise so far. Last weekend when I changed my wheels I thought it could be a good idea to get some rubber protection/ Maintenance spray to some of the suspension parts. Very very big mistake looks like. Since then I have a terrible annoying squeeking noise while driving. Coming from the front somewhere. What the hell this spray did what is producing such a noise. Any idea?
  8. I was driving now 1000 km nonstop. 34 degrees outside. Until now no major temp.problems. I adjust water level at home but without using the vacuum equipment. We will see what next days will show
  9. Such stupid mistakes from repair shops make me really angry. Same with me. My manyfold was 3 times off in the last 2 years. Starter. Breather Hose. 3. event i dont even remember. They dont think ahead. While already there i expect checking of items down. The breather hose for shure looks not good when they open first time for the starter. Nothing. 6 month later i went in for the hoses. They could do everything in one time
  10. Because a lot of coolant was gone maybe I should try to take out possible air pockets with the vacuum device before to investigate further. By the way, the old thermostat which is out can be tested in some way?
  11. @ Lewis Reminds me very much to my flex disc failure. Did you changed engine mounts when it was out?
  12. @Lewis water pump is new. Was replaced last year. Head gasket i really dont think it can be. I dont loose any coolant. No fuel smell in the coolant. No bubbles in coolant.
  13. Take all my courage and try to fix this by myself. Was actually easy but there are always some small things which dont work well and taking time and nervs. Finally i changed the thermostat. I didnt take out the cooling tubes. Just lift it up on the front to change. Unfortunately the temp problem is still there. Its just 25 degress outside but when the car stay in park for some time with engine running the gauge is showing very soon 100 degrees
  14. @weapons777 could you please let me know how you manage to unclip that panel to get access to the wiring? Please
  15. @ Lewis how long it took for your guys to take out the engine?
