Jeff Diffenderfer
Everything posted by Jeff Diffenderfer
  1. Howdy, I've just gone through a similar situation with my 1999 996 C2, and discovered the clutch pedal switch actuator (2' long bent metal bar that presses against the micro switch) needed to be opened up a bit. It's a gray switch and is mounted at the rear of the clutch pedal stem. The symptoms were finally clear to me when I pressed the clutch all the way to the floor and the car started consistently. Hope this helps Drift
  2. Try 0269 Loren! You are a Wizard! Works perfectly. A million thanks! Jeff D.
  3. This is a huge help. The original radio in my 1999 996 was replaced with a CDR 220 so porsche can't help me, or won't. Model Number: BE4462 SN 15062593 EC 114 Can you help please? Thanks, JeffD 996 "Rescue" Porsche (Saved from the crusher)
