Uwon
Everything posted by Uwon
  1. 2006 Carrera S, 130K miles mainly long distance, no track nor autocross. As noted in the topic, above, I have a ticking noise only on cold startup which goes away as soon as the coolant reaches about 90F. My first thought is sticky cylinders 5and/or 6 valves in which case what would be the best additive or procedure to diagnose (confirm/eliminate) this condition. I change the oil and filter every 4K miles and periodic oil analysis by Blackstone shows no unusual activity. Obviously, my ultimate concern would be bore scoring. thoughts? TIA Johan
  2. JFP, thank you for your quick and informative reply. Lots to take in. About the cat converter, what is their usual life span on these cars? Do you have a positive opinion on any of the various after market cats, such as Soul, Magna Flow, Fabspeed, etc.? I’m more interested in reliability as opposed to noisier exhaust. TIA Cheers Johan
  3. I have a U.S. model 2006 C2S with 131,000 miles which has been running great despite my fault code woes that keep coming back intermittently or do not clear at all. Of particular concern are those related to the engine, but nevertheless I have included all fault codes here as some "may" affect others. I use a Durametric Pro unit. I can only clear the fault codes in #1, below. All the other fault codes cannot be cleared either individually or by choosing "clear all fault codes". (1) Bosch Digital Electronics Motronic 7.8.1 P0420, Catalyst system efficiency below threshhold bank 1 P2099, Post catalyst fuel trim system too rich Bank 2 P2097, Post catalyst fuel trim system to rich Bank 1. Initially I had just lean as opposed to rich conditions in bank 1. As a result I replaced all four O2 sensors and leaking throttle body. Smoke test done with no leaks indicated. I now get these three fault codes if I drive the car about 150 miles. Sort drives do not seem to trigger fault codes. I have rechecked all the electrical connections to the O22 sensors several times. I am wondering if this is not a catalyst converter issue. Thoughts please before I spend money. (2) Vehicle Electrical System Current Fault Codes 8039, Filler flap actuating element The local dealer told me that this is a common problem with the 997 and they don’t even bother to fix anymore unless the customer insists. In my case the spring solenoid/actuator can be pressed in and bounces back but not enough to catch the flap. I’m not worried about this fault and only mention it just in case it is somehow connected to any other issue mentioned in this post. (3) Airbag -POSIP Current fault codes C152, Communication PSM control unit (drive) I have no idea what this means. would appreciate explanation and advice. (4) Advanced Weight System-AWS Current Fault System 8014, POSIP LN no communication I checked the yellow contacts under the passenger seat and they are plugged in properly and are secure. Does this issue affect the airbags? Any thoughts would be appreciated. (5) Porsche Access System-PAS Current Fault Codes 8004, Terminal 50 What does the PAS really do and what is terminal 50? I do not get a chirp when I lock the car. (6) Front Body Module Current Fault Codes 8028, Left fog light 8029, right fog light 8042, Front luggage compartment unlocking The fog light issues are my own doing as I have done a hack for my after market fog lights that are used as DLR’s with the switch in the Home position and pulled out to the front fog light position. I have no idea about the front luggage compartment unlocking as the lid lock works as it should with both the key and the latch in the door sill. (7) Air Conditioning Current Fault Codes 8035, interior sensor fan A/C works fine. Where is the sensor fan located? Any and all help and suggestions would be most welcome. Thanks in advance. Cheers,
  4. JFP, thanks again for your insight. I’m desperately trying to get an appointment with any one of several Porsche dealerships in the Toronto area for a PIWIS test analysis and will report back on my progress/resolution. These dealerships are all friggin busy this time of year. Cheers, Johan
  5. Thanks JFP. By way of background, which may now be relevant, I was trying to resurrect the DSC controller for the PASM which was not working. I reprogrammed it with no avail, so I reinstalled the the Porsche unit and the Durametric still said that the car was not equipped with PASM. In addition, I have had for some time a red “Current Fault Codes” indicator for the Air Conditioning but without any codes appearing. I cannot clear the red indicator. The A/C has been working fine. May these two issues also be related to the KESSY/PAS and is it dangerous for the car or driver to continue to drive the car? Thanks in advance. Johan
  6. Thanks Loren. First decent information I’ve had. Should have posted here first. Interesting that I can still lock the car properly but without any chirp. Also the fuel door does not lock which I had assumed to be a faulty actuator. Maybe it’s related to the KESSY/PASS. Thoughts? Johan
  7. '06 C2S....Durametric indicates fault U0167 being the "Communication PAS Control Module". I cant find any reference anywhere as to its location. Anybody Know ??? Does it go by another name or acronym in Porsche lingo? Thanks in advance. Johan
  8. The ignition key module on my 997.1 acted as you described. I think it is the same for your car. A quick DIY replacement corrected it, but then again, this particular problem is well known so you may have already done it. good luck Johan
  9. So great to hear. The guys behind the scene are so often the unsung heroes. Cheers, Johan BTW, you will enjoy the C2S. I’ve had the same yr/model for 11 years.
  10. Been following this thread with interest as I have a 997.1 S with ~120k miles that sometimes does the momentary chain rattle noise on cold startups common to the early air cooled cars. So, how does one diagnose the issue further? What would a Porsche shop likely do? listen with a stethoscope? Do you get a fault code eventually? Is it trail and error? First change the chain tensioner (cheaper alternative) and see if that eliminates the rattle? Johan
  11. Uwon
    Oil cooler
    Go to Porsche.com North America, classic car parts and look up numbers on respective PETs.
  12. You had a hydraulic not mechanical clutch. Does the ticking speed increase if you touch the accelerator lightly? Is it there at any time while driving? Johan
  13. Can’t tell model or side from pic. Overflow drain for either WW, brake fluid, gasoline or battery. Take your pick. Johan
  14. OK. You got me. What is an OBC stalk? TIA Johan
  15. The sticky ignition switch replacement is definitely a DIY item. Quite easy, actually. Search here, on Pelican, Rennlist, and/or Utube for the procedure. Sunset and Suncoast usually have the best prices. Good luck. Johan
  16. I really do not understand this thread. What “module” was blown? Why does the removal of headlights clear the problem of blowing the “module”? Why not just disconnect the battery? Johan
  17. Not on my ‘06 C2S. Those are for an ‘02-04 according to theBentley manual. Johan
  18. 2006 C2S, US car purchased in USA and brought into Canada by me. OK, I feel really dumb. I’ve been staring at the list of fuses in the little booklet stored in the fuse block cover-nothing even comes close, at least to me, that would resemble a headlight and/DRL fuse. What am I missing? Please see pic below. TIA Johan
  19. 2006 C2S I now have the Durametric Pro which I understood could change the DLR from headlights to fog lights. I downloaded the latest software but cannot find anything relevant. Any suggestions? thanks in advance. Johan
  20. If not already done so, suggest rechecking fuse amperage against manual rather than what was already in place.
  21. What assurance do you have that the car was not damaged and wrapped to hide a bad repair job? A wrap is not as permanent as factory paint. You will have to deal with it’s deterioration at some point. If the paint flakes off then it’s not factory. IMO the wrap would have to come off and paint inspected as a pre-condition. Otherwise run as fast as you can. Johan
  22. Year and model would be helpful (base, turbo, and, etc). Is it still leaking and from where? Front, back, which side, etc? did you recently ad oil or had the car serviced? Have you started it since and driven it? You sure the leak is from the car and not the lawnmower that you may have rolled across the garage? Johan
  23. First thing is to get a Certificate of Authenticity through Porsche North America. google and Porsche web site will be your friend. The certificate will tell you the color, options, etc. Post some pics of your car. This will help to get some feedback for you to consider. Cheers, johan
