rbrindley1
Everything posted by rbrindley1
  1. 2001 C2 manual coup @ 71K. Daily driver - every time I drive it's like a mini vacation. Replaced clutch, RMS and IMS with LN at 50K
  2. 2001 C2 with 65,000 miles as daily driver. RMS was leaking at 55,000 miles, which was replaced along with clutch and IMS with L&N. Also, I have replaced ignition lock at 60,000 due to failure. Recently (62,000 miles), installed Michelin Pilot Super Sport tires which I have been very impressed.
  3. Loren is right on. I had the same thing occur. Noticed it during an oil change, and sent an oil sample off to Blackstone Labs for analysis. The oil checked out perfect - no water or coolant in the sample. Those short trips on cold days will cause the residue to occur.
  4. GREAT DIY - Replace my lock and switch assembly over the weekend. I went the removal of the instrument cluster route, and concur the time to remove is worth it. In addition, one gets so much more room to work. A big thanks to all who added to this DIY, I for one certainly benfited from your learnings!
  5. JFP, Sorry for the typo!! Thanks again, Rob
  6. Thank you, JPF! Quick reply and the code worked like a charm! Thank you again, Rob
  7. Hi Loren, Had to replace the ignition lock and switch assemble (great DIY by the guys here - I went the instrument cluster removal route), therefore, I disconnected the battery resulting in the need to enter the radio code. I soon found out that I did not have the radio code with my manual set. So, if you would so kind, I would greatly appreciated it. Becker CDR - 220 Type: 4462 SN: 15062306 24/99 Thank you, Rob
  8. Got mine on the Monday....pretty good manual.
