Wausau 911
Everything posted by Wausau 911
  1. Search function is your friend - have you tried?
  2. When I brought my '04 C2 I made it a point to change all fluids so I would have a baseline going forward (brake, coolant, oil, tranny), even sent oil sample to Blackstone. Car had 55,000 on it.
  3. Loren, thx for the a part #, I have the same issue on driver side! wonder what causes this? Same part # for '04 C2? Is it a simple removal?
  4. An alternative I did utilized the Phillips DRL kit, about $85. Plug and play, ran wires through headlight moduals and placed the lights in the upper air ducts. Auto on/off and update the look of the car.
  5. Thx for reply Loren, unfortunately I don't have access to those. I was hoping for a manual engagement procedure.
  6. Is there a way to manual engage them? I have never heard them come on and just want to check they are functioning. Thx for replies.
  7. I placed it in with the bend facing the rear. Not sure if that was correct though.
  8. Does one of the edges have a roll / bend to it? If so it goes on the top lip of what might be called a rain guard. Mine was missing and I replaced it with that part. You can see where it goes when the sunroof is in the up position. Your pic seems like the part and it should be the exact size of the lip. hope this helps.
  9. I have oil dripping from bottom of filter housing. Replaced the filter 500 miles ago and it just started. Filter housing is on tight. Is there anything above the housing that would be leaking? Advise appreciated - thx
  10. When closing the frunk, do not press on the emblem after dropping it down from about 12". Rather put the palms of your hand on both sides of the emblem then press down till it latches. Pressure on the emblem will produce a dent over time.
  11. Yes, I did, search Pelican or Suncoast.
  12. Usually some on eBay.
  13. Saw a post about this oil tester product on a Austin Healey forum. Don't get me wrong here I utilize Blackstone at oil change but might consider this in between. Any thoughts on this out there?
  14. Thank you JFP, will do the easier route in spring if it ever comes to WI. Do I need a special Pcar fluid?
  15. Anyone have a write up on performing this service? Time and tools involved? Thx for all replies.
  16. '04 C2 - didn't see this called for in the manual's service requirements. Is this a good preventative exercise or a waste of money? Car runs good with all other 60k service done. Advice please & thx.
  17. Thx for the above post, guess I should read the manual more closely. Anyway, put my ear closer to the engine and the sound isn't coming from the pump, sounds more like it coming from the center, maybe alternator or a pulley.
  18. Thx for all the input, I'll check in the morning
  19. '04 C2 garage kept- but temps been in the high 20's in there, run the car every couple days and on startup, hear a buzzing sound coming from engine compartment. Goes away after about 45 seconds. New serpentine belt. Anyone have any ideas what could be making this sound? Replies appreciated. Thx
  20. As always thx Loren for your insight.
  21. Last question on this issue. Stock tire is a 285x30x18. Thx to Stuts, I found the OEM size at Discount tire direct for $404 each. The 265/35/18 is $242 each. Both are Michelin pilot sport A/S. Never drive over 75mph and use car around town and country roads. Will the lower cost tire be suitable as far as fitment and my driving style? Thx for replies.
  22. Thx for the replies, but the question is about mixing tire brands and tread differences. I understand age issue and compound variances
  23. My '04 C2 has almost new front 18" Michelin Pilot Sport A/S, came with the car last. I need new rear tires but the problem is the Michelin tires aren't available any longer per Tirerack, and they recommending Conti Extreme DWS. Never miXed tires before on any of my cars. Should I be OK with the Conti's? Replies appreciated - thx
