Edgar_vapes
Everything posted by Edgar_vapes
  1. @jagman1 thanks im gonna check that relay later today hopefully that's my problem wish me Luck 😁👍✌️ Any part numbers for that relay by any chance ?
  2. I have the same problem as of right now(Break proportioning & abs light and brake flashing light is on the dash)looks like Xmas tree in my dash😒👎, I lifted the carpet in the driver side and check the wires everything seems about right, there is absolutely no corrosion, or spliced wires, on the other hand the other day I was washing my truck and went to open my trunk to dry it, and I seen water creeped in the left rear driver side panel so I'm gonna take off that panel and check the rain gutters to make sure there Not clogged as this may be a culprit too my problem😔 any suggestions or help will be greatly appreciated😁👍
  3. I have a brake Proportining warning light on my 2003 cayenne everything works fine truck drives, the only thing that doesn't work is the speedo (mph) side,& won't mark miles as I drive it stays at 104k, rpm side works fine, from time to time the radio starts to turn the volume up or down alone, like if it has a mind of its own. One more thing the nav won't work it stays at my house street even tho I'm in another city, I checked under my driver side carpet everything looks good! Dry! I even check the 4 sonic welded wires that get corroded, they seem clean with No corrosion, checked all fuse boxes and every fuse one by one they all seem fine,any help would be greatly appreciated I'm trying to fix this problem ASAP thank guys!
