drspyros
Everything posted by drspyros
  1. So there is no way to stay with the after market performance remap, and at the same time make the car not to see the aftercat O2 sensors?
  2. Hello, If i had already remap my ecu for performance and now try to go from OBDII to RoW (i don't want the ecu to see the aftercat o2 sensors)....this means that i will loose the aftermarket map program? If i will lose it is there any way to do it with out loose the remap? Thanks!
  3. Thanks a lot for the help. I try to fix this problem as well as other problems i have. Thanks again!
  4. Same noise here from right rear, but dealer says that comes somewhear from the exaust. I have PSE, if it means something.....
  5. Hello, I think that i have the same problem...but not sure ;) That's why i want to ask you a question. Now that you have fix the problem the volts are about 14 as i saw at the photos. But when you turn on the lights, air condition and heating seats all together, does the voltage goes down to 13v lets say? Or it still stays at 14 volts? Thanks in advance!
