ZoSo
Everything posted by ZoSo
  1. 2001 Boxster S I had the same "hard to start after refueling. I checked all the same things I'm seeing here. The fix was the Regeneration Valve from throttle body for Fuel Vapor System Pt# 996-110-129-06--M100 You should be able to take a stethoscope hold it against the regeneration valve body where the electrical connection is and with the engine running there should be a noticeable clicking inside the valve. If none it's not working try tapping on the body it may start working.. I lubed the heck out of mine... Sprayed electrical cleaner with lubricant (plastic safe) and let it soak overnight put it back and I got another 7500 miles out of it.! Just recently replaced.. Now I'm with another problem.. I'll figure it out fix it and grr it's just worth it.
