Search the Community
Showing results for tags 'coolant refill'.
  • Search By Tags
  • Search By Author
Calendars
  • 911
  • Boxster
  • Cayenne
  • Macan
  • Panamera
  • Taycan
  • Classic Porsches
    • 356 Series
    • 911, 912 Series
    • 914, 914-6 Series
    • 928, 928S Series
    • 964 Series
    • 993, 993 TT Series
    • 980 Carrera GT
    • 918 Spyder
  • Events / News
    • News, Information, Rumors
    • Events
    • Work on Cars (SF Bay Area)
  • Other
    • Lost Radio Codes
    • Workshop Tools
    • Porsche Trivia
    • Forum Features Explained
    • Post Testing
Categories
  • Contributing Members Only
    • Tools and Diagnostics
    • Other files/documents
  • Public
  • Option Code Documents
    • Boxster
    • Carrera (911)
    • Carrera GT
    • Cayenne
    • Cayman
    • GT3
    • Macan
    • Panamera
    • 918 Spyder
    • Turbo / GT2
  • Service and Wear Parts List
    • Boxster
    • Carrera (911)
    • Carrera GT
    • Cayenne
    • Cayman
    • GT3
    • Macan (95B) (MY2015 - 2018)
    • Mission E
    • Panamera
    • 918 Spyder
    • Turbo / GT2
Categories
  • 911
    • 992-2 (911 Carrera) - DIY
    • 992-1 (911 Carrera) - DIY
    • 991-2 (911 Carrera) - DIY
    • 991-1 (911 Carrera) - DIY
    • 991 (Turbo, Turbo S) - DIY
    • 997-2 (Carrera) - DIY
    • 997-2 (Turbo) - DIY
    • 997-1 (Carrera) - DIY
    • 996 (Carrera) - DIY
    • 996 (GT3) - DIY
    • 996 (TT/GT2) - DIY
    • 993 (Carrera,Turbo) - DIY
  • Boxster
    • 718 (Boxster, Cayman) - DIY
    • 987-2 (Boxster/Cayman) DIY
    • 986 (Boxster) DIY
  • Cayenne
    • 9YA (Cayenne) - DIY
    • 92A (Cayenne) - DIY
    • 9PA, 9PA1 (Cayenne) - DIY
  • Macan
    • 95B-2 (Macan) - DIY
    • 95B (Macan) - DIY
  • Panamera
    • 971-2 (Panamera) - DIY
    • 971 (Panamera) - DIY
    • 970 (Panamera) - DIY
  • Taycan
    • Taycan Turbo, Turbo S - DIY
Categories
  • Cars For Sale
  • Parts for Sale
  • Tools for Sale
  • Items for Trade
  • Wanted
Product Groups
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
  • Start
    End
Group
MSN
Website URL
ICQ
Yahoo
Jabber
Skype
Interests
From
Present cars
Future cars
Former cars
Found 1 result
  1. Here is a tip on how to completely flush / refill your cooling system using a simple shop vacuum. To drain your system, first open both large and small tubes underneath the car, next to transmission and then connect a shop vacuum to the tubes to completely empty the system. To flush your system, should you want to do it, connect your shop vacuum to each tube and use your hand to inspect where the suction is. Then pour 1 liter of clean battery water or such from a bottle into a tube where suction exists. Just make sure you do not suck any dirt or your gloves in the system. To refill a completely drained system, first top off your coolant tank. You'll notice that you only get around half of the fluids in. Then connect shop vacuum to the larger tube underneath the car, next to transmission. Please watch your coolant level on the tank at the same time when you first activate your shop vacuum. You will see that the vacuum will suck level down pretty quick, only let the shop vacuum run for a second or so depending on how powerful vacuum you have. The point is to refill your coolant tank before the level drops too low and you get air in your system. Repeat this process of activating shop vacuum for a second and topping off your coolant tank as many times as you can. After around ten vacuum runs, you'll notice that you have filled over 20 liters to the system, still missing a few liters. Then open the clip on the coolant cap to relieve pressure, start the car, let the pump run and refill rest of the couple liters slowly, no CEL light or low coolant warnings should occur. At least for me this trick worked fine and the whole process was easy.
