Attention 987 owners - need 30 seconds of your time!
When you lower (open) your top, stop the process when the clamshell is still open but near the end of the cycle. Does your rear window put pressure or substantially rest on the black plastic bow (and cause it to bend) that clips the end of the headliner inplace?
Darius
I had a problem once when I re-closed the release (i.e. the handle over the mirror) before running the top down. Be sure to just pull the release open then run the motor. If this is not your problem, then no, I don't have it.
Edited by ZY971
