PArt number of longer bolts? (red)
The locking bolt is 996 361 057 90 and I believe the regular bolt is 996 361 203 90.
ed
any set of longer bolts available?
There is a tequipment kit that has 4 locking bolts with the key, and 16 non locking bolts. But this kit also has 5 mm spacers.
Otherwise, you have to buy the locking bolts which are sold as a set of 4 with the key, and 16 non locking bolts. Or, forget the locking bolts and buy 20 non locking bolts. I do not know of any other way unless you find someting on ebay.
http://www.renntech.org/forums/index.php?showtopic=8494
You can use the H&R bolts that are 7mm longer. If I remember correctly they are the 52mm bolts. You will have to transfer the collars from your original bolts to the new bolts.
WHERE H&R bolts? I am almost sure collars cannot be removed.
www.hrsprings.com
The collars can be removed. Many people have done this.
Here is a website that offers the Porsche bolts.
http://www.wheelenhancement.com/index.php?t=AccLugsLocks
ed
