I just switched out an ignition switch 4 months ago...Now I am getting a periodic no start. The switch/key feels perfect but the ignition seems as though it has a short? One time it works the next it does'nt. It has started eventually every time but obviously something is afoul. I am about as good a mechanic as Paris Hilton is an actress...WHAT IS THE PROBLEM??
A quick guess would be the start enable switch if you've got a manual. Press the clutch all the way down and you should hear a click just before the pedal bottoms out. Sometimes these get out of adjustment and they dont get actuated unless the pedal is completly mashed and if this switch isnt activated, well, no start for you.
