post-6892-1163039707_thumb.jpgAnyone know how to properly aim the headlights? I have read through the owner's manual but cannot seem to figure out which area of the headlight is for vertical aim and horizontal aim. Attached is a driver's side headlight assembly pic of the 3 areas for screwdriver adjustment, which one is which?
Your help is much appreciated, thanks!
Edited by edwin723
  • 2 years later...
Edwin,
Same problem with an '04 S. One beams higher than the other and want to adjust it. Any recommendations so far?
Joost
Cayenne : vertical adjusting screw = up/down horizontal adjusting screw = left/right
  • 11 months later...
