Rear Trunk Lid Won't Open
I am having a problem where the rear trunk lid won't open.
I had opened the trunk just a minute earlier and when I tried
to open it again, it just wouldn't pop open. I can hear the
locking mechanism pull back and forth, but it won't open. I
tried to push down and even tried prying alittle whith a screw
driver to get it open, but no luck. All fuses are OK, and I
wouldn't think it was the fuse as I can hear the locking
mechanism try to open. I have a 2001 S. All other car
functions are working fine, front trunk, convertible top,
windows, etc. What do you think, any suggestions?
If you need to get into the trunk to get to the locking
mechanism, how would you do that? Is it even possible
or would something like removing a fender be necessary?
Yes, It is the same with the key switch and the door sill switch.
I wasn't aware that there was a cable for the rear trunk like they
have for the front. I will check in my manuals to see if I can find
where it is located. Can you direct me to where it is located?
(Sorry for posting in the 987 board, I didn't see that you seperated them).
OK, So I see it on your photo. The question is how do I get to it?
What exactly do I have to take apart to get to it? I took a look under
the car and I see the heat shield that is above the muffler that blocks
you from getting to it. Can you get to it from the wheel well? The only
thing I have left is to try and get to the emergency cable and give it
a pull. Until I get the trunk open I won't be able to tell what the problem
is.
You want to stop by and assist in seeing if I can get to the cable? Maybe
this weekend? I live at San Tomas and El Camino now. 408-244-1589. Let
me know. By the way, The manual doesn't give any help here that I can
find.
OK, I fixed the problem. The Bowden cable had slipped out
of the conncetion at the motor/actuator. Here are the instructions
to get to the Bowden emergency cable.....
1: Jack the driver's rear tire up and remove. Take care not to
chip the brake caliper paint (use the tire removal bar).
2: Remove the rear part of the wheel well. Note; There are
3 hidden bolts you need to remove in order to get the part
of the wheel well out. They are hidden under the bumper
skin. Pull the bumper back and you can get to them. They
are 10mm nuts. Take care not to pull the bumper skin back
too much (it is pretty flexible).
3: There are 2 screws under the bumper skin you need to remove.
They are Torx head (T25).
4: Remove piece of wheel well and look back towards the inside of
the bumper skin and you will see the pull cable.
Give it a pull and the trunk should open.
Now that the trunk is open you can investigate further as to what
the problem is. Mine was the cable had slipped out of the connector.
I had to take apart the mounting hardware for the spolier hardware
as the motor/actuator for the latch is under this. There are a couple of
screws that are no easy to get to or put back in. The nuts are 8mm
and the screws are Torx heads (T25). I took out the actuator and reseated
the cable. I put the actuator and mounting hardware back together and
tested it to make sure it was working. All looks OK.
You will also need to pull the carpet out of the trunk to make it easier
to do the work without trying to hold it back.
Also, I left the cable hanging out between the heat shield and the bottom
of the insdie of the bumper skin. It is still hidden, but I can get to it if this
happens again (Rear Trunk Bowden Emergency Cable Mod!).
Oh, Jeff, I still have nightmares from jumping up and down on your front
hood even if it was wrecked. One is just not supposed to do that to a Porsche.
Anyway, 1st problem I had with the 2001S and it wasn't due to broken parts.
So, where are you parking your Boxster these days....
