After I dismantle the brakepads from the calipers I notice that the pads don't have contact on the whole disc during braking. About a 1cm on the outer edge of the disc don't have contact with the pad. The pads are the same which I dismanteled.
I have tested with some heavy braking to "settle" the pads without result. What have done wrong and what should I do?
Are you sure if the rotors are not out of limit ? If yes, replace. If not, rectify the rotors.
How do I rectify the rotors? Why should I need to do that when I put the same pads on the same placement as before the dismantle. Is this a case each time you change or dismantle the brakepads?
You can file the outside corner of the pad so it sets down evenly onto the worn surface of the rotor. It's probablly sitting a bit more to the outside than the last set.
