The short shifter arrived today but before fitting it I'd like to get a few answers.
1. How is the gear knob attached to the gear leaver? My previous 944 used a simple clip to lock the knob in place, I do not see something similar on the Boxster's gear knob.
2. How do you detach the gear selector from its cradle? I assume the 2 nylon bushes needs to be forced out.
P.S. Any hints and tips from someone that already performed the task will be appreciated.
Cheers
The standard shift knob is a very tight friction fit. The optional shift knobs have a set screw. Unclip the boot/gaiter and see if there is a set screw.
To remove the 2 white plastic cup bushings I break the tabs that hold them in place with a small wood chisel. Watch your eyes as they fly when you wack on them with a chisel.
