Brake Caliper Help
I had my previous 986 painted in red with duplicolor, and now want yellow on my current 987 to match with exterior color.
The problem is all caliper paint I can find is "bright" yellow, doesn't quite match with speed yellow.
Q1. The paint spray from paintscratch.com can be used for caliper? If it's not a good idea, anyone has a picture of speed yellow with the bright yellow caliper?
Q2. Which clear coat should I use?
Thanks in advance!
