Hi, my in-dash CD Player is acting up, it's been hot the past couple of days, so I'm wondering if it's heat related, but when I turned it on, I got the error unable to read CD. I tried ejecting an MP3 disc I made and it wouldn't eject. Only after a power off and back on of the car did it eject. I inserted a regular CD and the same error. This time it took much longer to get the CD out.
Ideas?
Some PCM 2 have this problem, it's a warranty issue.
Okay, do you know if they replace everything, and if that means you loose your stored addresses for NAV?
Thanks again!
They read out the PCM completely with PIWIS and read in the new unit, if nothing go wrong, al the addresses are saved.
