Click here to Donate
front end knocking noise
HI, drive a 1998 996 C2 with 66K on the clock and just started to notice a knocking type noise and vibration coming somewhere from the front end. It only starts after about 30 -40 miles and stops after the car has cooled down for an hour or more. someone suggested a wheel bearing may be the cause but can anyone help? cheers
I had similar and thought it was the lower control arms which are quite common and same symptoms as you describe. But it was the track rod ends. The MD was useless as diagnosis - replaced top mounts (twice) , control arms and finally track rod ends.
