Help - Just Replaced Battery And The Battery Light Is Now On
Help, I just replaced my battery down at the local autozone and everything went very smooth. They took the old one, swapped in the new, connected it back up and car started up with no issues. But on my way home, the Battery / Charger Light came on (the Dash). I carefully drove it into the garage and shut her off.
So as I look through the manual, they state that the battery light coming on is a big enough deal to immediately stop the car. Does anyone know how a simple swap of the battery could cause the Battery Light to come on? And what I could do to fix this issue. Thanks in advance for any responders! Could this be an alternator issue?
Hopefully its not something serious but its been one of those months with this car! :( Needs new CV boots on the left rear, needs new right rear bearing, had new tires recently put on, and during the 60K mile maintenance, new brake pads, new right rear CV boots and a few other minor things repaired). So its been quite a money pit...but you gotta love the drive!
:renntech:
BTW - 2002 Boxster S. Replaced the original Moll battery with the Duralast 48-DL.
Edited by jvmoney
I would guess the alternator, but don't know how changing the battery would have anything to do with it, unless the terminals were reversed and the alternator got fried. Have Autozone test the alternator to see if it is charging. There should be about 14 volts with the engine running.
Does your radio work? If the terminals were reversed then alternator can short, then the fuse on the back of the radio can blow. Fuses for the cd changer, ABS, and control unit under the seat can also blow. A mechanic told me all the electrical things that can get fried, but those are the ones I remember.
