Amplified Ignition Coils
Can anyone tell me if coils on a 2002 3.6 Carrera are internally or externally amplified?
thanks
Marcus
If you mean are the ignition coils actually step-up "transformers" then the answer is yes.
But externally the 12 volt battery voltage is "amplified" via a DC to DC inverter to ~300 volts and that is used as the coil primary
"switched" voltage.
12 volts to ~300 volts to ~25,000 volts.
thanks
Marcus
"switched" voltage.
Thats great thanks for the info.
Marcus
