I recently purchased a pair of litronic headlights got my 1999 C2.
I've noticed that there is an extra plug on them that I don't have a harness for.
Where can I find the parts and instructions to help with this?
The plug is for 4 wires that come from the control unit. The litronics will work even when not hooked up to the control unit. Just put them in.
The control unit is for auto-leveling I presume?
Is it too much effort to install?
Thanks for all your help, you're great.
No the control unit is for mixing the low beam with the high beam when the brights are on.
Auto-leveling can not be retrofit - it is only available from the factory.
The only trick to adding the control unit is having a pin tool for the electrical socket - or being willing to splice into an existing wire.
