Guest carpediemgr
I think it is time to check the compression on cylinder 1. You could have a broken piston ring or bent valve.
compression checked all looks fine!!!
i forgot to say that when the check engine lit on 6000rpm the power of the car dont drop , still keep accelerate fine.
a stupid question is any possibility that my brother bought this car remember he has run only 100km after bought it and... he didnt know that the car has a "chip" mean reprogramming the ECU? for best performance and the seller didint told that? is it possible a ECU tunning do problems like this?
thanks
Typical catalyst problem, once over 6.000 rpm the cats can not absorb the volume of exhaust gasses they're cleaning capacity are reduced, take apart the cat section and give a look inside with a endoscope, i bet that they are partial blocked or even melted. The CEL will blink at that moment, if you loose the throttle the CEL go's out.
HI ALL
This is my first try here. I have a 986 97', 2.5, with 58.000 kms and I've the same problem. I have an PIWIS Tester, and yesterday gave me the codes: P0300, P0301, P0302. Then, after this, gave the codes P1319, P1314, P14 and P1315.
We changed the spark plugs, and changed with the left side two coils, but the fault codes still remain the same. The codes only comes at 5.500 rpm. Do you really think is catalyst problem?
Best regards
João Berjano
Guest carpediemgr
still my head is close to break
HI ALL
Best regards
João Berjano
joao in my brothers car after 6000rpm the car still have power dont drop and go without problem accelerating to red line rpm after the rpm drom lower to
6000rpm the light stop lit
the car accelerate like a "gun" dont show that something happening with lifters or pistons
but who can tell me that if they open the engine the problem will stop?????
in official dealer shop the had changed half an engine outside part with the same problem and finaly they changed engine because the car was in warranty
Edited by carpediemgr
Guest carpediemgr
the last think i have to do i will do is to go to Official Porsche center i make an appointment on tuesday.
i have another 4 days for the problem to be ended without pay another 50% of a new car :)))))
i will leave my pants in the porsche center !!!
Guest carpediemgr
any other here with same problems?
Guest carpediemgr
tommorow i will know from the official dealler ... hope not to need a new motor after 42000 km .....
Guest carpediemgr
finally for problems with codes everyone have to take official dealler opinion
the problem was the 1st cylinder coil
the not official shop proposed to change lifters on bank 1 lol........
just 200 euros for new coil than 2500 for engine repair......
Guest carpediemgr
my happiness was for 3 days
coil and plug changed from official porsche dealler but after 3 days the problem is back
misfire misfire.....
now the check engine light is lighting all the time dont stop light when rpm drom down of 6000 rpm
my brothers car is close to be in big troubles
2003 with 42000 km on i cant believe it
Guest carpediemgr
Relax carpediemgr, the fact is that fault finding needs insight and organisation and is a job on his own. If you are not in a possition to do it by yourself bring in the car to a dealer and pick the car up when the repair is done, with warranty. Every body satisfy.
i did it my friend already
in germany last serviced they know the problem
here in greece the official dealer try to find it by changing the half of my car parts
did you understand?
i pay all these part during the diagnosis....
tommorow they will try for a new catalitic converter the next day for a new ECU brain etc
i have to pay another car in pats? in the other deallers shop in Reultingen they already had made this diagnosis why i have to pay again?
explain to me... i am the stupid? explain please? why ????
why they dont ask from Reutlingen germany the historic to find out the problem and fix it without ask me to pay all these paqrts during the diagnosis?
In reultingen germany they have already made that diagnosis of the problem
Edited by Loren
Remove flaming and warned member
Guest carpediemgr
dear friends no one can tell what the problem is the car is in official seller workshop for 10 days and still wait to explain to me what this fault 300-and 301
total misfire and misfire in cylinder 1 wich caused when the car is over 6000rpm happens
what is going on?
This topic is now closed to further replies.
