Hi
I have a loose cable with a loop at the end in my engine department. It looks like it's hooked to the lock. I would think it's the releasing mechanism. But I can still get the hood up by pulling the trigger from inside. This time I have to almost pull it up with my nails. Where does the loop hookup?
Here's a picture of the cable?
Kristian
I have a 1999 carrera 4 convertible 6spd
Hi
Kristian
I have about two feet of loose cable that I have to fold so it wont get in away. I just can't see why it would be there if there is no purpose for it ? :(
Kristian
The loop doesn't hook anywhere.
That is the rear lid release - if it is open then it is already released.
Normally it sits behind the left rear wheel well liner. The idea (I think) is that you can reach it behind the liner and pull (should the mechanism cable/solenoid fail).
Got it
Thanks again
Kristian
