Hoping someone can help me out with the following issue.
Tried starting my 2000 2.7ltr that had not been started in 2weeks with no success
I received audio beeps as well as warning light with windows flickering up and down
Booster the car with success and let it run for approx 10 minutes
Tried to restart with success
Left battery charger on car, but the warnings I mention above have not disappeared
My thoughts are that there must be a reset of some sort for this type of situation, but I looked through my manual and it does not speak of one.
Any thoughts on what I need to do to get warnings to disappear??
Thanks in advance for helping a newbie
Is it possible to start the car after charging and without a booster ? You have to be sure concern the battery condition, 100% is the reference.
If yes, try this:
Note the code for the radio or PCM
Disconnect the negative cable from the battery
Disconnect the positive cable from the battery
To preserve for accidents - remove the battery
Connect the negative and positive cable with each other by using a start cable for 15 minutes
Install the battery
Connect the positive cable to the battery
Connect the negative cable to the battery
Do the learning process for the windows
Insert the code for the radio or PCM
Hope this help.
I know it maybe a dumb question but what is a start cable? By connecting the pos and neg together does this reset the computer?
If yes, try this:
Install the battery
Hope this help.
We call that start cables, i don't no in English. It consurns a set of cables, 1 red and 1 black, sold in auto stores to connect a spare battery with the car battery to start up. Connecting poss. cable with neg. cable is the ultimate manner to reset all control boxes, with the battery REMOVED to prevent you for accidents.
In the US we call these Jumper Cables.
Manny thanks White, i note down these, we are never too old to learn.
