Boxster Rear Tail Light Access Carpet Fasteners
Do you have any idea of the part numbers for the two (on each side and different sizes) black round plastic fasteners that secure the carpeting to the rear tail lights in the Boxster trunk? My dealer stripped them, and it is probably less hassle to tag them onto a parts order from Suncoast than to waste my time and gas griping with the dealer. They are about 1" and 1-1/2" in diameter if I recall. Thanks!
On the early cars both were the same size but I notice when we work on the newer cars there are 2 different sizes.
Check with your parts person but they should be 999 049 020 40 and 999 049 024 40. The first part number should be the large one and I hope the second is the small one. Called a plastic nut. About a dollar for the pair.
  • 2 years later...
