Aircon Sponge Problem
Ouch, i would have hoped they improved this design but considering my 87 Passat Tdi had this issue there are a few thing VAG won't give up...but I digress,
It will eventually deteriorate enough that the foam will be gone and assuming your heater box is the same design leave large exposed holes in the mixer door. These hole will keep your heat and ac from being optimal based on your primary need. Since the ac on these small cockpits is large considering the space I didn't notice an issue but the heat was lacking. Once fixed my heat was great and the ac was disturbingly cold if needed.
It could take 6 months or 6 years to come to pass. Unless you have an extended warrenty worry about it once there is an issue with heat or cold, especially if you are at the start of "just getting" foam.
