I have a 1996 993 Tiptronic. When its in 'Park' on a gradient without the handbrake applied, the car will roll downhill with a 'click click' noise from the transmission. What is the likely cause of this, is it an expensive repair? If so, how much engineering would be required to fit a manual gearbox to the car?
I guess it needs the gearbox, master cylinder, clutch and pedal box assemblies and hydraulic lines, but are the manual and tiptronic cars actually different, ie no holes in bulkhead for clutch pedal, different computer, different flywheels etc?
  • 4 weeks later...
I spoke to Patrick Motorsports at www.patrickmotorsports.com who have done conversion work like this. They say it would be a very expensive job with extensive labour and control unit costs. Cheaper to sell the car and buy the one you want.
