Anyone know how to replace the coolant temp sensor. I can't seem to find it on a search and the only manual reference I have for it lists the GT3 only and the pics look different.
thanks
2001 C2 Coupe Tip
The sensor is located below the power steering pump all the way at the bottom of the engine below the inlet hose. Get on your back and get under the back of the car below the passenger side bumperette and look straight up. You see the small 4 pin sensor with cable connected to it. It is about a $25 part. Disconnect the connector, remove the sensor (catching the coolant as it comes out), and replace. Filter the coolant through a coffee filter and pour back into the coolant tank. Bleed system.
