I'm thinking of replacing all bulbs on the back and the side to LED bulbs. Has anybody done it and has
anybody run into any problems?
Kristian
Kristian
No problems other than I may have had to modify the current sensing resistor in the solid state turn signal flasher relay.
Converted all of our vehicles to LEDs and I don't remember which ones required modifying.
Oops, almost forgot.
The 996 cruise control will not work absent stoplight resistance load equivalent to at least one incandesent filament.
I used a 12 volt relay with a 9 ohm resistor connected via the N.C. relay contacts.
Edited by wwest
