pcm with navigation system
The PCM 1 code is wrong or the unit is already replaced, sometimes you have to push in the navi. code after the PCM 1 code, sometimes not it depends what is happen before. In case the PCM unit is replaced i will hope that the tech. pushed in the new codes in the DME section as info, so that the dealer can pick up the codes.
