I assume that is a P0140
If so...
P0140 Oxygen sensor behind catalytic converter, open circuit
Possible fault causes
- Fault in the oxygen sensor heater, if this exists, is to be taken care of first
- Loose contact or corrosion in the connector
- Open circuit in the signal leads
- Open circuit in ground lead
- Oxygen sensor faulty
- DME control module faulty
