Interlock and Brake Warning Light
P993
I have a 1990 C4.
After driving for a while sometimes the Interlock and Brake warning light will simultaneously get activated. The Owner's Manual explain it a s the "pressure reserve is too low".
Brake fluid is at Max.
Any input into this will be very helpful
Thank you.
it is probably related to the pressure switch in the booster.
if you cycle the key does the light reset?
Yes. Is this something I can ignore? How difficult is it to replace this switch and if you know the part number?
Thank you for your help.
I have a 1990 C4.
Thank you.
This is a very common problem that so often is caused by nothing to do with any of the logical causes. The most common cause is high voltage feedback from HT leakage from the coils or the distributor caps and/or rotors. Check the state of these items before you waste time and money looking for problems that don't exist.
Dave
  • 3 months later...
