I just bought a 2000 Boxster 2.7 5 speed. The window on the dash where the clock is located is not illuminated. All the other dashboard items work. Is there a fuse that needs to be changed or maybe a bulb in the dashboard itself?
Each LCD display has a bulb behind it. When a bulb burns out then you cannot see the display. Need to remove the instrument cluster in order to change the bulb on the back of the cluster. There are already several messages with pictures on how to do this.
